Changing objects name via entity info window not possible
Hi
Are others also having problems renaming objects via the enitity info window while VRayForSketchup.rb is loaded ? it seems to keep reset the text input field :frowning:
Also, I can’t use the build-in feature - like entering 10x in the textbox :frowning:
Jorgensen
