Could it be possible to increment time limit while rendering?
Maybe Im wrong but I have noticed that changing noise limit or passes, this values could change during rendering, but not with time, I know that after the time limit finish I could continue with resume, but sometimes I need to leave to do other stuff and the image seems to need more time.
Sorry, I don’t understand the request, can you provide more details? Do you mean that you could start a render, then update the Time value in the render settings dialog, and this would change the target for the currently active render so that it stops as the newly entered time and not at the time target set at the render start?
As a note, this doesn’t happen with Noise Limit or Passes either, as once the render starts, it will always stop at the targets set when it began and doesn’t change if those targets are updated after the render starts (as a note, e.g. if you change the Noise Level, the VFB Stats panel may update to show the new Noise Level target, but the render will actually stop at the Noise Level target set when rendering began).
Or perhaps I am misunderstanding and you are asking for something else? Also do you mean final render only, or IR only, or both?
Thanks for clarifying Tom, you understood it correctly.
I was the one who misunderstook the process behaivior. So in that case, could it be possible to use the update target? if not, maibe its better to have the info displayed without update so theres no confussion.
I only meant for Final Render, I think with IR I can change at any the values I need.
The only thing that I have asked before but get decline is to have a time value for IR, personally I dont use passes, it completely varies of the scene, I only use it when I need to update certain regions in Final render.
TY for the reply! I’m going to decline the Idea, as a final render should not allow you to change the target noise / passes / time once it has started. What we have logged is that the VFB should not update to show those new values while a rendering is in progress, to avoid confusion (that one doesn’t need an Idea here, we’re treating that more as a kind of bug). Thanks! Tom
