When I create a Daylight System, then change the sun in that Daylight System from a mr sun (default) to a Corona Sun, the Corona Sun is created as a targeted object with the target locked to the origin. If the Daylight System is not created at the origin, the apparent rendered time of day does not reflect the actual time selected in the Time/Date/Location setup in the Daylight System. This is because the Corona Sun is looking at its target, which is at a different angle than the center of the Daylight System. I now have to make sure the Daylight System is created (or moved to) the origin. I previously did not need to do this. The new behavior appears to be that the Corona Sun now has a target, which I don’t think it did before. I did not install RC1, but have noticed this in RC2 and RC3.
On a side note, is there a way to have the Daylight System automatically use a Corona Sun?
