Changing Vray Material default parameters
Hi, I always done a lot of same thing in a vray default material. Like removing fresnel, switching to ggx . Is there the possibility to create my own default material and have it load in the material editor as default?
In 90 % of my material i’ve got composite in the same slot or curve…It will be easy for me to edit it once and have it ready all the time.
Thanks.
Alessandro
Hm, maybe you can edit the medit.mat material library that is normally found in “%localappdata%\Autodesk\3dsMax\2016 - 64bit\ENU\en-US\defaults\MAX” - this is the file that is used to populate the slots of the material editor when you open it. You can adjust the settings as you want.
There is no way to change the defaults when you create a new VRayMtl material though - will make a note to look into that. We did some work to implement presets for the VRayMtl material, maybe one of them can be used as default.
Hi Vlado, thanks for the quick reply.
I try to do it but with no result. An other think that i try to do is to manually set all the material editor slot like i want and save a new maxstart file. But when i reset they come back to their initial state. Any idea of how to prevent the resetting?
Alessandro
I solve it like this: http://forums.cgsociety.org/archive/index.php?t-926377.html
Next time i will do more google search. Thanks again for answer me.
Alessanro
Ok then :slight_smile:
Being able to save/load settings/defaults on anything VRay object/properties related (or max related for that matter, but that is not your problem) would be really cool.
you could do that with scripts of course they are there for this kind of things :wink:
