Chaos Academy: Scene does not render
Hey guys,
we have a new apprentice here in the company.
I thought it would be a good idea if he goes through the Chaos Acadmy courseware.
Sadly one of the scenes is not rendering at all. Tested on different machines using Max 2027 and Vray 7.4.04
The scene in question is 05 - Natural Lighting - Sun and Sky Archviz.max which can be found in this segment here:
The scene gets stuck in the preparation phase, mostly on the terrain.
Could you please check what’s going on? It would be great if the scenes Chaos provides actually are rendering without flaws…
EDIT: A quick debug showed that the slowdown is caused by the grass layers inside the 04_Scatter group in the layers.
It seems the Chaos scatter has issues with those.
Thanks for the report. I’ll troubleshoot.
It renders fine on my end. It just took a while to load, scatter instances, etc.
The scene takes around 42 GB of RAM, half of which is indeed from the grass (the count of which may be excessive).
Go to the Grass Lawn 01/02 and Grass Wild 001 scatter nodes and lower the Count (Surface Scattering rollout) to 100/100/250, respectively, and it’ll run much faster, yielding similar results.
Yeah, it will render eventually.
But on our end it takes around 10 minutes before you can do anything.
Changing the light as shown in the course get’s quite tedious.
