As per the title, i just installed Vray6 and when trying to test Chaos scatter, it’s not visible in the create menu. Anybody knows what I’m missing? Thanks in advance.
Maybe you already found it but if not then it’s some separate icons on the top toolbar…3 little trees.
Those 3 little trees were also not visible in the toolbar… I uninstalled, cleaned as much as i could all of the chaos stuff and reinstalled, that did the trick.
Ah ok, well glad you fixed it in any case ![]()
