Chaos Corona 10 for 3ds Max - Daily Builds Discussion
Hi guys,
I think we have these crashes fixed internally already, but I’d love to test it out on one of your scenes so we can make sure it is really fixed for you as well.
Could anyone send me over a “crashy” scene?
Cheers,
Rowan
I followed marchik’s scenario and it crashes as he says.
It’s a heap corruption error (0xc0000374) but I don’t think it’s related to scattering itself.
If you disable Global Illumination, it seems to work just fine.
I’d guess it’s a GI problem when interfacing with some functions.
Hey,
So we looked into this, it seems it is caused by the chamfer modifier and it is crashing completely outside of Corona. Did you update 3ds max around the same time?
I tested the scene all the way back to v9 HF1 and it was consistently crashing upon opening in each daily.
Thanks,
Rowan
Hi Guys,
Crashes during parsing and GI calculation that you reported should be fixed in the latest daily (2023-02-27).
Please let me know if you have some issues still.
Rowan
Here is a simple test of the new Optix:
(crops attached)
Сursor still doesn’t change its shape when using region rendering in VFB, but it works better
The fix for that is coming :smiley:
Rowan
This is fixed in the latest daily, you can grab it here: https://forum.corona-renderer.com/ Chaos Corona 10 for 3ds Max - Daily Builds Changelog #msg210302
Cheers
With the latest DB I almost constantly get “Render had to be aborted because a bitmap on disk changed and is being reloaded. Continuing the render could cause crash or undefined behavior…” during IR.
Bitmap has not changed. It happens when I link bitmap to material or assigning material or just pick material from scene. Different scenes, different materials, different bitmaps.
Does it happen with both regular bitmaps or with CoronaBitmap as well? Asking because I’ve not had it happen with the CoronaBitmap, only with the regular Bitmap from Max.
Glad other people mention this, I have it happen in every scene of every project with any kind of random material. Pretty much makes any IR work completely impossible to work with :- ). Happens 100perc. within first run of IR.
Will try to isolate and package scene but next two days are impossible for that.
Hi Devs
latest daily - when changing material parameters - the IR doesnt change it unless i resize the window or restart IR.
Hey guys,
Some scenes with reproduction steps would be super helpful here. Please use the link in my signature to send them over.
Cheers!
(Internal ID=1070545683)
Hi Devs
I saw a video on youtube where the CURVE editor within the VFB could be undocked and expanded - has this feature been removed from dailies?
Yes, but the hope is it will be added back sometime in the future: https://forum.corona-renderer.com/ Curves in Corona 10
great - hoping its in the next release - the curve editor in that little window is next to useless to use.
About “render has to be aborted…”
Clean scene - create some object, start interactive, create material, apply to object, load bitmap, connect bitmap to some slot of material and you’ll get an error. The are other scenarios as well. Not sure but seems like problem only wit max bitmap.
Thanks! We have managed to reproduce this one. We’ll do our best to fix it asap. A workaround for the time being is to use the Corona bitmap :smiley:
Cheers,
Rowan
Issues with 3ds max bitmap causing IR to stop have been fixed in the latest daily. Please check it out and let me know if you still have issues!
Rowan
hi rowmanns, it is still happening.
