Chaos Corona 12 for 3ds Max and Cinema 4D released!
We are excited to announce the release of Chaos Corona 12, which introduces eagerly anticipated features to help you create and explore beyond limits!
Full details and download: chaos.com/blog/corona-12
What’s new in Corona 12:
  • Corona to Vantage scene export. Import your Corona scenes into Chaos Vantage to render test images in seconds. Create animations in Vantage and enjoy the lightning-fast speed of GPU real-time rendering.
  • Curved Decals. Easily bend labels around curved objects like bottles and spherical items without distortions.
  • New Virtual Frame Buffer (VFB 2). Use the new VFB features like A/B image comparison, multiple LightMix setups within one render, and deferred bloom and glare calculations.
  • Corona Pattern improvements. Create new and incredibly realistic materials with the help of Corona Pattern. Geometric objects can now be used to define the shape of the crop box, allowing designers to employ snapping tools and more to get the perfect pattern.
  • Scatter Instance Brush (Corona for 3ds Max). Enjoy full creative control over the scattering process with a brush tool to refine procedural instances.
  • Corona Sky improvements. Enhance day-to-night transitions with even lower sun angles adding an extra layer of realism.
  • New Density parameter in Corona Sky. Customize your cloud density in one click.
  • Corona Material Library is now available on Chaos Cosmos, which will save you time when switching between asset libraries.
  • Enjoy a more streamlined workflow with the new Cryptomatte by material.
For this release, everyone gets a full 30-day trial period, even if you have used a trial before, to give you time to try out all the new features.
Remember, you can read about this release in detail over at chaos.com/blog/corona-12
Webinar: Explore beyond limits with Corona 12 & Chaos Vantage
Join our live webinar to learn about the integration between Corona 12 and Chaos Vantage, including its current capabilities and upcoming developments.
Our special guests from Narrativ, Luis Inciarte and Robin Walker, will present their latest project, showcasing how they experimented with Corona 12 and Vantage to achieve impressive results.
Sign up for the webinar: chaos.com/webinars/corona-12
Try Chaos Vantage: chaos.com/try-vantage
