unfortunately, no matter what I do, in this version, 3ds max freezes on lightmix or in some instant edits in the scene while rendering in realtime and I have to close it and open it again. in short, it stutters and I close the program completely.
note; my processor amd ryzen 3970x thripter processor
Hello Chaos Team,
I’m encountering a serious issue with Corona Renderer 13 (RC1) while using 3ds Max 2024.2. When I launch Interactive Rendering (IR), Max becomes completely unresponsive within seconds and freezes indefinitely.
System Specs:
- CPU: AMD Ryzen Threadripper 3970X
- RAM: 128 GB
- GPU: AORUS RTX (24 GB VRAM)
- OS: Windows 11 (latest updates installed)
- Corona Renderer: 13 RC1
- 3ds Max: 2024.2
Issue Description:
- The freeze occurs both in VFB IR and Viewport IR modes.
- As soon as IR starts, 3ds Max locks up and becomes unusable.
- CPU usage spikes and stays at 95–100% constantly during the freeze.
- GPU usage remains very low or near idle.
- Tried even with a simple scene (box + light only) → same issue.
- Only way out is to terminate 3ds Max using Task Manager.
Troubleshooting Steps I’ve Tried:
- Disabled all 3rd-party plugins and scripts → No effect.
- Reset all Corona render settings to default → No change.
- Updated GPU drivers (NVIDIA Studio and Game Ready versions) → No effect.
- Switched between VFB and viewport IR → No difference.
- Windows and BIOS are fully up-to-date.
Notes:
- This issue did not exist in earlier stable versions.
- If needed, I can provide:
- Screenshot of Task Manager showing CPU spike
- A sample scene that reproduces the freeze
- Corona system log file
Has anyone else experienced similar behavior?
Any advice or workaround would be greatly appreciated.
Thanks in advance!
textureStats.csv (8.93 KB)
Continuing in support ticket #387362.
I have been having this same issue and it is unbearable. have you been able to figure it out?
whenever i am using the IR and make a simple edit such as raising the exposure or changing the white balance by utilizing the mouse sliding up and down the file VFB just decides to freeze.
this only happens while in IR. it is incredibly frustrating.
I can see from the image you are using denoising? Have you tried disabling real-time denoising? Disabling Bloom&Glare (if enabled)? Limiting the real-time thread usage?
I am also on 3970x and have been getting freezes that may be VFB-related.
I second this. Try disabling IR denoising in the Performance tab and check if you are still getting the freezes.
The previous case was solved by updating the graphics card driver.
I will try disabling the IR denoising, but why is this happening? I have my graphics card drivers up to date running a 4090 with Corona 14 Update 1.
I’ll also try disabling bloom and glare because i do notice when it freezes the bloom and glare is still processing continuously as if the IR is still active.
just came back to confirm the VFB still freezes even after disabling bloom&glare.
this doesnt seem to be file related. it happens across all of the projects i have worked on. im scared to make any tone mapping adjustments while in IR because of these freezes.
How about disabling IR denoising?
Could you please capture a minidump file while 3ds Max is frozen and contact us with it?
Here is how to capture it (see point 2) - https://support.chaos.com/hc/en-us/articles/4649117083409-How-to-report-issues-3ds-Max
And you can contact us here - https://support.chaos.com/hc/en-us/requests/new
