Chaos Corona 9 for 3ds Max - Daily Builds Discussion
Chaos Corona 9 for 3ds Max Daily Builds Discussion
You can grab the latest build from: [Daily Builds Changelog](https://forum.corona-renderer.com/ Chaos Corona 9 for 3ds Max - Daily Builds Changelog )
Dont know if someone has checked this but, the file for the last Daily “corona-9-3dsmax-daily-2022-06-09” isnt avaiable, it says that the file has been erased
It’s working fine here, can you check again?
As a note, this was just a pre-release of Corona 8 HF 1, so it is still better to just download the final Corona 8 HF1 anyway, from Download | My Chaos
Thanks for answering Tom, I have already checked again and the message its still there, but my mistake, I didnt read that this changes has been placed on Corona 8 HF1, so… sorry for the inconvinience.
No inconvenience at all - for one thing, we need to find out why that is happening for some people with the link (even if the link itself is no longer needed due to HF1), so it was good to have this reported!
Hi ,
what are the differences between Corona8 hotfix2 and corona8 hotfix1 for 3ds max?
thanks
Corona 8 Hotfix 1 changelog: https://forum.corona-renderer.com/ Chaos Corona 8 (Hotfix 1) released, for 3ds Max and Cinema 4D
Corona 8 Hotfix 2 changelog: https://forum.corona-renderer.com/ Chaos Corona 8 for 3ds Max (Hotfix 2) released
Basically, Corona 8 Hotfix 1 had a bug which resulted in a crash under specific circumstances. This is fixed in Hotfix 2.
Also, please note that this thread is meant for Corona 9 daily build discussion. :smiley:
Thank you for answer,
…“Corona8 Daily build discussion” and “corona8 daily builds changelog” are closed.
Hi dev.team, could you please add support to showing multisub maps in viewports.
I mean the only one map is shown in the viewport while several maps applied with different IDs.
Testing out Corona Pattern.
Omg, love it! Already amazing and stable from my first experiments.
In fresh DB I can’t enter tonmapping values in VFB using the keyboard (see the attachment), after pressing enter, the values return to their original state, the spinner works as expected
CoronaPattern works like a charm, I only have 2 questions:
  1. is it possible to add a random rotation option, this would come in handy when scattering grass samples
  2. Is it possible to add a scaling option (in order to get an overlap of individual patterns and not cut them strictly in a rectangle)
    however, as far as I understand, point 2 is not feasible in the current realities
Thanks for reporting this. It seems to be to do with the , delimter. As a workaround you can change the delimter in Windows to a . and it will function correctly. We hope to have this fixed soon :smiley:
Cheers,
Rowan
(Internal ID=930143568)
Please post your impressions, reports and requests about Corona Pattern in this topic: https://forum.corona-renderer.com/ CoronaPattern playground! so they don’t get lost here.
Thanks for the feedback.
  1. Could it be because of viewport clipping, scene units, or the scene being far from origin? Crop box never disappeared for me when zooming in. Can you try with orthographic view and see if zooming very close to crop box make it disappear.
  2. This is already reported, thanks
We’ve had discussion with Rowan about this and it seems like it’s caused either because of my 3ds Max version, or more likely because specific issues with my OS. Thanks for looking at this nonetheless.
Corona VFB won’t change Tone Mapping parameters my typing digits and enter, works only by spinners
This has already been reported and we are working on a fix. Please see my earlier message for a workaround..
Cheers,
Rowan
Hello guys, weird thing is happening with hdri map loaded into enviroment slot.
Setting corona bitmap U tiling to -1, the dome appears inverted into the enviroment (the same obviously with the value set to 1).
So corona dome projection and env dome projection are always opposite to each other.
Hi, where can I post feedback about Chaos Scatter?
CS losing instanced objects on Max’s Batch rendering (CS instances clipped by camera in the option Camera Clipping - Enable Active render camera).
