Is it normal that all the cars assets provided by “Fisherman3D” vendor doesn’t have a red brake lights material when used with 3dsMax and Corona ?
The render isn’t the same as the preview in Cosmos, everything else seems ok.
How is it possible without Vray installed to customize the material file where Cosmos picks his material ?
I’m looking for a solution where the defaults proxys clicked in Cosmos could be properly loaded into our scenes without tweaking the materials everytime we use one of them.
I presume that the it’s a Corona Mat conversion because the preview is OK. I could change all the .VRMesh loaded in the scene, but I haven’t Vray at the moment and it would be quite a long operation to open each of them and adapt the Glass Material.
Waiting for someone at Chaos to give us a feedback about it, thanks !
I also posted this problem report into the Chaos Cosmos forum.
Well it’s not juste the brake light in fact, it’s all the red glass material wich compose the rear light of all the cars.
If I would like to make it brake I could insert a CoronaLight Material in the right spot, but that’s not the problem here.
This issue is already logged in our system and is being reviewed by our devs. Meanwhile, you can turn on the “Thin shell” option in the “Glass Red mtl” to make it work.
