HI, when i download some assets from Chaos cosmos i get an error, the mesh is only a proxy and when i change it to mesh i get just the white mesh without textures and i can’t pick the material from the object. any help?
Hi, can you please clarify what the error is exactly? Does this happen with a specific asset or anything you’ve tried?
I have the same problem. Object without textures 2022-04-24-202953 hosted at ImgBB — ImgBB
Does it render without textures or is it just for the viewport?
Same problem here, objects have no textures and render with no textures in 3DS max 2016
Can you please clarify if you are using a custom asset download folder, also, is it local?
Yes i use a local custom asset download folder
problem solved by changing the asset download folder. I used a folder name with a “é” and it’s seems it was the problem
(Report ID=CRMAX-1599)
