chaos cosmos for vantage to add lights and primitives, center pivot, improve the objects panel, uvw map textures on objects, edit basic parameters in materials
dear Vantage team
can you please collaborate with chaos cosmos team to bring a few things in cosmos library that are necessary when you work with vantage standalone.
Now with Vray 6 for rhino,that translates enscape models and materials my workflow in vantage has transformed.
Instead of working in 3ds max live link, I work in vantage stand alone where i combine several vrscenes, from rhino, 3ds max.
Then there might be a few mistakes in the model that I could not foresee, and specially with light composition.
So I would like to be able to drag and drop lights from cosmos to Vantae. plane light, omni light , disk light… and the other thing few primitives like box or cylinder in some cases where you want to fill a gap in the model.
one click center pivot to object will be much appreciated as well as the possibility to uvw map textures of a material or change parameters of the material, in a simple way.
if you can improve objects panel hierarchy to be able to fast select objects of same layer..
Hi digital_technologies,
We have talked about these requests with the cosmos team and they have them in their backlog. Cannot say when they will have the time to implement them however. I will try to increase the priority for it.
The UV and material parameters manipulation is something we plan to do but at a later stage. I will log in your request for a faster selection of objects in a hierarchy.
Alexander
I am happy to say that primitives have been added to the Cosmos library. Just type primitives in the search field and they will be listed: https://drive.google.com/uc?id=1OW8m5wzoU6EOI2goi1qB4ULbksG7rGUl
Please note that they are accessible to Vantage users only, meaning you can only see them inside the Cosmos browser from Vantage and they will not be listed if you look for them from Rhino or Max, for example. If you wish them to be accessible from all other cosmos integrations, please write in the Cosmos forum section.
They are working on adding individual lights as assets as well but cannot say when they will be published.
Alexander
