when using Chaos Cosmos Materials (the soon to be standard for corona materials) I get various Error Messages when rendering.
Specifically with concrete grey 03 … but i bet its a common problem with chaos cosmos objects or materials.
In this Case i get an error message, that Normal maps have incorrect gamma. Even if i apply / or remove “add gamma to input” the error message will be the same.
Since the annoying use of .tx file format, its not possible to alter the files in Photoshop to replace the input to get rid of the error-message.
I don’t like to have error-messages everytime i render - then the real errors will be overseen.
Other than that - if chaos is basically forcing everyone to use chaos-cosmos (out of additional revenue or whatever reasons) then it would be best advised to proper manage that library and be sure that even with new releases of rendern-engines the assets are up to date and working.
