Chaos Scans + Corona + RoundEgdes
Hi!
Offcourse awesome we can now use Chaos scans with Corona Render. But if I plug a Corona Round Edges Map in the Custom Bump channel of the Scan, nothing happens. As I am unable to bevel the edges in the mesh, this would be my only solution.
Is there any way I can fix this?
Hi, this seems to be similar to the question in this topic , but since vray and corona differ, the solution may be not the same.
The original question in the toipic above was exactly about “bump slot”, that is missing in the vray implementation, general purpose bump node (VRayNormalMap) is used instead. As i understand in corona there is dedicated bump slot, i will ask the coworkers in the corona team, but if there is something similar to the VRayNormalMap you can try with it
