Hi, everyone
I recently updated the software, I try to open old projects and get strange problems with vray7 and 3dsmax2025.
It was very unexpected to see extra objects in the scatter on the render, and in the viewport everything looks fine. I did some tests and realized that CPU renders everything correctly, the GPU is incorrect, the Vantage(LiveLink and vrscene import) is incorrect.
It turns out that there are extra objects been scattered between the line splines. Although such splines have never been in the scene. I have to make each segment a separate line and add a lot of lines to the scatter.
I hope someone knows a solution? Because now it is difficult to work with projects, where many plants are planted along the lines and you need to manually redo everything one element at a time.
Thank you
