Chaos Scatter C4D - Not Only Splines
I find that the controls for the instances of the Scatter still could be much more complete. For one, it would be nice to be able to use 3D objects as attractors for scaling and inclusion/exclusion, not just splines.
Then it would be great it we could control the curve of this attraction, for example make it non-linear etc. Similar to what C4D can do with Cloner and Fields.
Hi, thanks for your request. It has been noted. (Internal ID=1232972403)
Awesome, thanks!
I believe you can also add a Corona distance shader in the distribution channel and then add any 3d object you like to that.
