I have imported chaos scatter objects from 3DS Max into Vantage. They display fine. However, I would need to turn them on and off visibility using “Scene sub-state” and unfortunately that doesn’t work for me.
Example: i create a sub state where the scatter is visible and save it. In the second state, the scatter is hidden. When I switch from the off state to the on state, the scatter remains invisible…
It works the same way in reverse - If I have the scatter visible first and use another state to make it invisible, it stays visible.
Any idea what to do about it?
We have a fairly large project at work with lots of cameras and green space - 15 kilometers of new road. My idea was to put all the cameras in a row in a timeline and use “Scene States” to determine what will be visible when for the render, everything works except for the scatter green. If I turn on all the greenery at once, some objects go black.
Thanks for help!
Adam
