Chaos Scatter Stopped working
Hello
I have a few chaos scatters , I can see them in the viewport but none of them render anymore. They render in CPU , does GPU not support Chaos Scatter?
Using max 2024 and Vray 6.2
So the help says its supported,
I have reinstalled and also tried it in a simple test scene but nothing is rendering for me.
Hi @dubsyman_sousand
Indeed, Chaos Scatter is supported on VRayGPU - sorry to hear you are facing issues.
Can you recall if Scatter worked on GPU in the past or this is the first time you are actually trying to run a GPU render with Scatter? I also have a few other questions:
1. Do you receive any errors in the render log when when starting the GPU render? If so, can you copy-paste them here?
2. Have you ever had Chaos Corona installed on this machine?
3. Are there any other user profiles on this machine? Any special characters (non-latin) in the username?
4. Can you try to uninstall V-Ray + Scatter again and make sure any leftover files are removed:
C:\Program Files\Chaos Group\Scatter\3ds Max 20xx;
C:\Program Files\Chaos Group\V-Ray\3ds Max 20xx;
C:\ProgramData\Autodesk\ApplicationPlugins\VRay3ds Max20xx;
C:\Users\<username>\AppData\Local\ChaosGroup\V-Ray for 3ds Max 20xx
any Chaos Scatter leftovers from old installs in C:\Program Files\Autodesk\3ds Max 20xx\Plugins,
then run the V-Ray 6 installer again?​
Hi
Yes it did work in the past, I had all these trees and bushes setup in it.
I only have this warning in the log
] Warning : EdgesTex/RoundedCorners is not supported through procedural texture
  • ​Corona is installed but in trial mode I was using it to convert some textures.
  • The latest change I did was I installed vray for houdini.
  • I dont have any special character profiles.
  • will try clean reinstall .
Hi, thanks for posting. Please try to uninstall your Chaos Scatter from Windows program files and after that reinstall V-Ray. There is a similar issue discussed here.
After reinstall is working, Thanks
