Chaos Vantage 3 released
Hello everyone!
We’re excited to announce the release of Chaos Vantage 3 - a major milestone in our continued effort to streamline the production pipeline with high-quality pre-visualizations, accelerated interactive rendering, and highly efficient playblasts.
The official release contains all the features from the beta and a few more. The major features of the release are:
  • Support for static and animated USD file formats (.usd, .usda, .usdc, .usdz).
  • Support for MaterialX material definitions.
  • Initial support for importing and rendering volume caches (.aur, .vdb) from Chaos Phoenix and VRayVolumeGrid.
  • Support for rendering Gaussian Splats from .vrscene files and Live Link.
  • Added Material editor for creating(VRayMtl, Blend, Multi, Hair, Light) and editing(created and imported) materials within Vantage.
  • Support for V-Ray night sky and moon.
  • AI Material Generator in Chaos Cosmos.
  • Support for Object Clustering in Chaos Scatter.
  • Support for VRay2SidedTex.
  • Support for probability parameter in MultiSubTex​​.
  • New Selection Mask and Alpha view modes.​
  • Support for camera tracking with the following protocols: LONET 2, EZtrackTCD, FreeD, stYpe HF.​
  • Renaming of Render Elements.
  • Support for applying transform changes made in Vantage to animated .vrscenes.​
  • Redesigned UI with changed color palette, resizable side panels, new Home Screen, Render mode.
  • Enhanced the Lavina renderer to better handle very large numbers of unique meshes.​
  • ​and more…
You can find more information here:
Chaos Vantage – Pure ray tracing in real-time | Chaos
To get started, visit this link:
https://try.chaos.com/chaos-vantage
You can find the full change log here:
Release notes
You can download the new version from here:​
Download Vantage 3
We look forward to your invaluable feedback and insights! ​Thank you all for your support! We hope you enjoy this major release!
The Chaos Vantage team​​
Hello everyone!
Hotfix for Chaos Vantage 3 has just been released and here are the major highlights:
  • Added MultiSubTex, Gradient Ram, Bezier curves, 2Sided material and Override material UI in the Material Editor. Now they can also be created inside Vantage.
  • Support for controlling the Smoke opacity and Fire rendering for the Volume grid object with new parameters and curves.
  • Added additional clouds density and contrails parameters.​
  • Support for the “random by tile” parameter of MultiSubTex​.
  • Improved displacement tessellation: reduced excessive triangle count with the per-triangle option and increased overall speed for tessellation.​
  • Improved Render mode performance. Now the UI interactivity should match that when not in Render mode.​
  • Volumes incorrectly affect alpha of objects behind them.​
  • Vantage not receiving updates in Live Link from 3ds Max when VRayEnhancerData render element is present.​
  • Crash when playing or scrubbing timeline on scenes exported via “Vantage Anim. Export” from Corona​.
  • Save PNG Alpha" option not working on all sequence offline rendering tasks.
  • Fixed transparent rendering of Objects when both “16-bit PNG” and “Save PNG Alpha” are enabled.
  • Fixed only first sequence task with render elements saves with correct filename frames, subsequent tasks write as a single frame.
  • ​Fixed sequence queue item(s) being deleted upon scene reload from .vantage file.​
  • Fixed animation FPS not stored or recalled correctly from .vantage file​.
  • Fixed Vantage saves corrupted .vantage files when there are NaN/Inf values to save (e.g. the camera transform)​
  • Fixed glowing in Volumes and Gaussian Splats when switching from DLSS to OptiX.​
  • ​and more…
You can find more information about Vantage here:
Release notes
Download Vantage 3
The Chaos Vantage team​​​
