Chaos Vantage 3, update 1 - Memory Issues
Hi!
I’ve noticed that the new Chaos Vantage 3, update 1 has some memory issues I’ve never had before.
I have an RTX 4090 24GB and now when it reaches 16GB in Vantage the SW gives me memory errors or some objects disappear from the scene/viewport.
Any ideas what’s going on?
And Merry Christmas to everybody!
Thanks,
Dionysios -
- Can you give more details about those errors? What are the error messages?
- Are other processes using significant amounts of VRAM, like other 3D software? Even browsers and chat apps do that.
- Have you checked how much main RAM is used? In some cases errors could occur when RAM is exhausted before VRAM.
- Are you sure that the version of Vantage is the only thing that changed, i.e. you’re using the same scene and settings, the same running apps, etc.?
Hi Nikola,
the setup of my workstation is the same as a month ago and nothing has changed. I have 128GB of ram and this is not the issue.
The thing I’ve noticed is that Vantage, while it gives me 16GB used in the app with all the assets loaded, the software sometimes just writes in the error log window that the Vram is not sufficient.
The scene I was working on while I was having this behaviour is smaller than the one I’ve finished 2 months ago with the previous version of Vantage and I had less memory issues at that time.
Note that such errors could occur if there is a large piece of geometry that requires a singular large block of memory (the debug log could contain info about that). For example if you have 8 GB free and the large mesh requires 10GB it will fail to load and you will not see memory usage reach close to 100%. Another aspect is memory fragmentation - you may have 8GB free and you only need 6GB, but the largest contiguous free piece of memory is 4GB so there is nowhere to fit the 6GB.
Also, building the raytracing data structures requires some additional temporary memory, so even if the scene would fit in VRAM when completely loaded, it may need a few more GB of peak memory usage while loading.
Great, good to know all this!
