Chaos Vantage v2.2.0 released
Hello everyone,
Chaos Vantage v2.2.0 has been released and here are the highlights.
  • Added support for V-Ray displacement
  • Added support for V-Ray Fur, Ornatrix, Hairfarm and XGen hair
  • Added support for V-Ray Hair Next material
  • Added support for Intel Meteor Lake iGPUs
  • Added support for V-Ray 6.2 instancing
  • Added functionality to save the Render Setup options for offline rendering in the .vantage file
  • Added Vantage Live Link settings dialog, launched using 3Ds Max Vantage toolbar
​You can find the full change log here:
You can download the update from here:
You can see some of the new features in use here:​​
Simeon and the Vantage team
Hello everyone!
Chaos Vantage v2.2.1 has been released with the following changes:
  • Added support for Material ID in displacement
  • Fixed а crash with mesh file with thousands of voxels
  • Fixed а displacement UV scale issue in Sketchup
  • Fixed а crash with empty geometry Node with added displacement
  • Fixed а crash with animated ForestPro objects in 3Ds Max Live Link
  • Fixed broken displacement continuity with specific scene
  • Fixed clay mode removing displacement
https://download.chaosgroup.com/?platform=47&product=63​​
Hello everyone!
Chaos Vantage v2.2.2 has been released with the following highlights:
  • Added support for Chaos Scatter in V-Ray 6 for Maya, V-Ray 6 for SketchUp/Rhino update 2
  • Added support for Edge Trimming in Chaos Scatter and Forest Pack in V-Ray 6 for 3ds Max update 2
  • Added Include models’ children, Edge trimming, Altitude limitation, Preserve model rotation/scale and Look at target options in scatter object inside Chaos Vantage.
  • Improved camera imported from SketchUp - now view matches when using Two-Point Perspective (CameraFilmTransform plugin in .vrscene)
  • Improved camera - increased limit for number of cameras from 100 to 1000
  • Improved camera - now Field of view does not change between cameras with different focus distance when in Field of View Lens mode
  • Improved physical sky responsiveness - now it is computed on the GPU
https://download.chaos.com/?platform=47&product=63​​​
Hello everyone!
Chaos Vantage v2.2.3 has been released with the following highlights:
  • Added support for instancing lights with Chaos Scatter
  • Added support for VRayMultiSubTex in Chaos Scatter
  • Improved the speed of loading vrscenes with a small number of very detailed meshes​
