Chaos Vantage v2.6.0 has been released and here are the highlights:
- Added support for V-Ray Clipper
- Added support for the VRayMtl SSS Translucency mode
- Added support for opacity in Stochastic mode of the VRayMtl
- Added Water surface object
- Added support for the PhoenixFD Ocean texture
- Added support for transparent VRayLightMtl
- Improved Cameras represented as objects
- Improved camera transitions with smoother trajectories
- Improved support for animated Camera clipping planes
- UX improvements
You can find the full change log here:
You can download the update from here:
You can see some of the new features in use here:
Hello everyone,
Chaos Vantage v2.6.1 has been released and here are the highlights:
- Added presets for the Water Surface object
- Added support for vector mode displacement for the Phoenix Ocean Texture.
- Added SSS to the GI render element
- Fixed unwanted camera creation for each camera move during Live Link when using .vantage scene loaded as a config
- Fixed crash when loading a config file
https://download.chaos.com/?platform=47&product=63
The Chaos Vantage team
Hello everyone,
Chaos Vantage v2.6.2 has been released and here are the highlights:
- Added an option for LOD bias when dynamic textures are used
- Added the name of the selected camera in the scene animation track
- Improved asset import - when dragging onto empty space, an implicit plane at height 0 is used for placement instead of the scene origin
- Fixed the selected scene animation camera not being saved in the config file
- Fixed black sky when the V-Ray 7 PRG sky model is selected. The V-Ray 6 model is still used
- Fixed wrong rendering of Mesh clipper with SSS
- Fixed wrong wave scale after hiding and showing a Water Surface object
- Fixed ignoring the “loop animation” preference option when merging scenes
