Chaos Vantage v2.7.0 has been released and here are the highlights:
- Added support for the V-Ray Dirt texture
- Added support for the V-Ray 7 Scatter density patterns, edited scatter instances and scatter surface color
- Added support for camera lens distortion with ST maps
- Added support for Open Color IO color management.
- Added Blur/Sharpen post effects
- Added support for the camera vignetting and optical vignetting
- Upgraded DLSS Ray Reconstruction to version 4
- Added animated camera path visualization in the viewport
- Upgraded the PRG Clear Sky model with added altitude and turbidity parameters
- Improved UI navigation speed
You can find the full change log here:
You can download the update from here:
You can see some of the new features in use here:
The Chaos Vantage team
Ymauchi
2
Congratulations on the release of Chaos Vantage v2.7.0!
The development team is working very hard.
Can I share the ST map library used in the demo?
Or is it distributed somewhere?
Users would benefit if Chaos Vantage included typical ST Maps such as lenticular lenses and fisheye lenses.
Hi @flat , you can find some examples here:
We will add more there as well.
Simeon
Ymauchi
4
Hello everyone,
Chaos Vantage v2.7.1 has been released and here are the highlights:
- Support for custom density texture, for the Chaos Scatter, which is using an UV channel different than 1
- Added functionality to store the post effects in EXR files
https://download.chaos.com/?platform=47&product=63
