I keep seeing mentions of Chaos Vantage, but never knew what it was. I watched part of a Chaos video and the main feature, from what I saw, was real-time (or close to it) previews. Isn’t that one of the great features of Corona and V-ray, and Octane and Redshift for that matter? We have ability to have good real-time previews and updates as you work. Why is Vantage needed if the engines already provide a similar function?
Chaos Vantage is a whole application with its own UI and real-time GPU renderer - Chaos Vantage
If all goes well, we may have Vantage support in Corona 12 - Trello
That would mean, for example, the ability to walk through your scenes in real-time, change lighting, materials, and more. BUT please note that it’s still early, so there are no promises at this point (and I am not the best one to share such updates anyway). I’m sure Tom will drop by here soon.
So the big thing is adding GPU tech to a CPU render engine. Interesting. Sounds like Unreal Engine. I would also assume that Mac users might not be able to take advantage of this tech. Not Chaos’ fault, just stating the obvious. Thanks for the info.
it is as far i understand there is also “game tech” used (direct x12 and nvidia things) under the hood, and it can deal with amazing huge scenes in real time, classic apps or render exports like c4d or 3dsmax itself would be never capable of handling this that fast. so it is quite more than just adding gpu rendering, but a complete new architecture under the hood to manage the geometry in real time.
there for an extra application. i use it and it is pretty amazing, it is real time with bruteforce (=pathtracing) and light cache (like coronas UHD), so very good quality, using very intelligent denoisers to manage that in real time, you can even mix nvidia and intel denoiser in its settings.
also the interface is now becoming real nice and useful, more like the modern engines like d5 etc, but will full cosmos, chaos scatter etc support and direct connection (to vray for now).
i very much hope corona 12 adds support, (otherwise i probably would’ve to switch back to vray)
for me it makes me happy, as I see chaos is here top notch again on newest tech and I not have the feel I need to switch to unreal or other new real time tech out there.
For an initial release, it could well be that functionality is limited to exporting to Vantage, after which any changes you make in Vantage will not appear back in your Max/C4D scene. There is no plan for a live link style functionality, though we will see how things go over time; but for now it’s viewed as a one way conversion to vrscene to enable opening it in Vantage. You would still be able to edit in Vantage just as any other scene in Vantage, but as noted that would remain just in Vantage.
The expected purpose at the moment is to very quickly render previews, or if the needs of your client match the differences/limitations of GPU rendering, finals. Ideally this would be for, say, animated fly throughs too as that’s when saving some rendering time for previews would be most useful, though again we’ll have to see how far things go in the initial implementation in terms of animation. For 12 though the idea is to get the basic foundation in place and then go from there
PS the speed of Vantage compared to IR is very different
Very interesting. So the quality is very good in Vantage, but not production quality. It seems like a condensed version of Unreal Engine. Not sure I will need it in the future, but good to know it might be there at some point.
To clarify, there would be no “price increase” for using Vantage, just that it’s a separate product you would need to purchase to be able to use it, meaning you’d have to buy two products not just one. This is not the same thing as “price increase” which is a change to the pricing of an individual product
On Vantage for Mac, a question to send to the Vantage team (the Chaos forums should have a section). I would suspect not due to the usual issue of the graphics hardware being very different on Macs (or at least those newer ones that have moved away from using NVIDIA cards in them etc.).
Hahah yes, that was where I was pointing out the individual cost for Vantage that you’d have to subscribe to on top of the Corona subscription. There’d be no change to Corona pricing itself of course
Was just watching the Chaos Unboxed presentation. Lots of interesting stuff coming. Since this thread is about Vantage, they also showed Enscape, which to the uneducated eye, seems somewhat similar to Vantage.
The Cosmos a.i. material generator would be amazing if it produces truly usable materials.
