check/clean-up scenes that takes ages to load?
What are you guys using to clean up scenes that are taking ages to load?
I remember some years ago using sini to remove anim layers or something like that, that could help a lot, but now it no longer seems to find that type when running it. I have a scene now that takes 10-20mins to load and I would like to be able to troubleshoot it. I.e. is it due to some specific assets on a network drive making trouble, is it Forestpack having issues or missing enscape assets from the fbx export etc.
The file is huge and bloated (2.5gb without compress on save and 800mb with compres). Can’t share due to very strict client NDAs.
From my experience, specifically with large files over the past few years, big files just take long to load. And i have seen this pattern with other software too, e.g. Revit. A 500MB file for Revit can be considered big, and I had one which opened for 35 minutes. My max files usually do not go longer than 5 minutes to open, but I guess they are not big enough :smiley:
I would suggest XRefing the scene to parts and opening each of them to see which one takes long.
Surely, if any of them have a specific Corona related object, which you think takes long to open (e.g. we had optimization for Volume objects, which in rare cases could load quite long), report it and we will have a look.
Do you have any XREFs? I have a scene (condo tower) where I pulled all the furniture out and xrefed it all to keep the compressed max file below 2.5gb. Scene load time jumped from 5 minutes to 20 minutes. It would just sit on the infamous ‘loading corona assets’ or whatever it says in the lower left bar (I know that’s not an accurate ‘Status.’). I nuked the xrefs and voila, back go normal. So then I brought in the furny using Corona Proxies and load time went up slightly but not nearly as much. I sometimes wonder if it’s a Xrefs don’t like Network storage thing…although I have 10gbe but still Max doesn’t always love networks.
Long story short, you using xrefs? Possible to remove all and test?
Not sure how much each of the steps contributes to the total reduction of opening time but some routine we have in an office is this:
  1. Prune scene, inspect with SiNi and delete any missing plugins / animation layers etc.
  2. Make sure you don’t have many external paths in your 3ds max settings. There are different views on this but generally the more paths you have on Customize > Configure Project paths, the longer each file will load as 3ds max will check each folder before opening the file to see if it can find missing bitmaps there. This is even more annoying when opening old files, as paths are usually lost so max tries to scan each folder, and there might not even be anything project related there. Sometimes this can even crash the file so better practise is to have few paths in there and later relink missing bitmaps manually, or with some scripts.
  3. As others have mentioned, xrefs play a huge role too. There used to be a script that disables xrefs when opening a file (can’t find it right now), but I found another script that could also be useful - it disable all “missing this and that” pop-ups when opening the file. This is extremely frustrating when opening large files again, as you might forget about opening a large file for a while and when you press on it you suddenly realise it was waiting for you to press SKIP. You can find it here - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-suppress-Waning-dialogs-when-opening-a-scene-in-3ds-Max.html
  4. And lastly of course, if you work over network it’s highly recommended to copy file locally, do what you got to do and then copy it back to the server. This can cause massive lag depending on your network setup, file paths etc. I sometimes forget that I have Everything running in the background, scanning all of our server and it just freezes the server completely if it needs to load anything.
  5. Final advice, after opening an old scene I recommend merging everything into a new file, doing some quick cleaning and re-saving it. Sometimes, depending on how old some projects are, because of many new Corona / 3ds Max versions old things tend to break even though nothing got changed. So this merging procedure allows you to double-check if everything is alright (merging in parts of course) and generally is a good time to setup your scene nice and clean.
Hope that helps.
Thanks for all the good tips guys. Most of them I’ve tried, but the script Mase linked to is super nice to just get to open max files without all the fuss of having to click “next” after having waiting for 20min :smiley:
I didn’t have any xrefs nor network paths in user/project defined paths. Mostly all textures are located on a network drive, so that is for sure cause of some of the loading time.
My max file itself and proxies are locally on my PC due to the slow network (with max).
I have been importing large(ish) fbx files quite a few times over 1 year or so as the project is ongoing - I don’t like linking the fbx - so there might be some conflicting naming/missing textures messing stuff up too or just bloating the file as I tend to hide the old stuff in case I have to go back.
Running Sini cleanup actually caused crashes to the scene on some occasions, like removing unused plugins and some file relinking. A sign that the file indeed was getting sick, so I have no ended up merging everything into a new max scene. Ideally this was what I wanted to avoid as there’s usually issues here and there. Here’s some of them:
  • Issues with “real world size” on UVW modifier on some objects. A new UVW modifier usually fixes it or a reset x form, but still annoying.
  • Some camera’s were turned 180 degrees (an odd one I haven’t seen before).
  • The biggest issue however is that Pulze’s Scene Manager setup hasn’t transferred over. So I have to setup all 15+ camera’s and custom settings (have emailed their support in hopes of there’s something to about it).
Regarding the script, I think I tried that one a while back and the part I didn’t like is that it would no longer prompt on Units Mismatch, making the choice for itself. Not a deal breaker for everyone, but I didn’t like losing that level of control (and maybe the script has been updated to resolve this?) Just thinking that might relate to your first and second issue depending on your scene units and system units…if the default choice is ‘scale objects to match units’ then that could be one reason why you need a reset XForm?
Regarding the Pulze issue, have you tried their Import\Export function? It’s the button up top that looks like two arrows one facing left one facing right. I’ve never used that feature myself (and I couldn’t find documentation published on it for you) but my assumption was always that it was to transfer scene setups between max files. All this is assuming you’ve got a Pro license.
My $0.02, hope that helps.
I think you are spot on regarding the difference in scene units. Pretty sure the old file was in mm and my standard setup is cm. At least now, the viewport doesn’t flicker so much. I thought this was purely due to the model being so far away from 0,0,0 but maybe it’s more tied in to scene units? Odd.
I tried checking the script and it basically only says: “set quite mode to on”. Had hoped I could change something in the script to have it default to “change scene units to match file scene units” instead.
Pulze support was quick to mail me back regarding the import/export button. Like you, I tried searching for an option in the doc on that function, but didn’t find anything either. But yes, it saves a max file that you then just import via the same button and the setup is there again. Very nice.
Thanks for the 2 cents, I very much appreciate everyone’s willingness to help on here <3
I think its a function of units but also distance from the origin. I once had an Archicad > SU > Max import that was thousands of feet away from the origin and everything about the model was awful…flickering, viewport culling issues, extremely slow to load and work in, etc. I ended up grabbing the FBX base point (the XY dealie) and moved it a set amount to get the main model closer to the origin, made a note of it, and then actually hid the FBX icon. I seem to recall that that helped but it was never quite as normal as a typical import for me. The better thing would have been to move the model in SU closer to origin before even importing it. The smaller your system units the worse\more common this issue is, I think. Gotta have to do with mathematical precision\rounding or something.
Couple of things to check;
Groups: And Groups, inside Groups, Inside Groups, Inside Groups. Best not do this. Use Layer Manager instead. The extended hierarchal tree dept really slows everything down, from opening the scene to parsing before rendering. You can even attach all elements of the object if possible to avoid overreliance on groups.
Modifiers: For every modifier attached to an object, Max makes a copy of it (so as to be able to revert to original in a non-destructive way). Six modifiers on an object, six hidden copies of that object. If possible, collapse stack and save as a new collapsed version of the file. Again this will impact opening times and rendering precomputation.
Also the new Scene Cleaner in Corona (Paintbrush Icon in the Corona Toolbar) can really help slim a file down. I’ve had it reduce scenes to one third of the size of the original after using it.
Regards,
Yeah, same when we get rhino, dwg files etc. Moving everything natively in those programs to world 0,0,0 yields a much better result on import in max. Especially dwg splines will interpolate much more cleanly in curves etc.
Great tips! I had no idea the groups->groups was an issue. I often get sketchup files and some architects are notorius in doing groups with groups withing groups. I usually ungroup everything and attach by material (SiNi script). Only thing is I loose the ability to edit components as instances and make importing new changes bit more troublesome, but still worth it.
The modifier thing I had no idea about either. Or well a little, it’s especially obvious when trying to use the native max sculpt tool on large landscapes if I have multiple edit poly modfiers on the object. Very bad lag and performance using the brush, but if I collapse the mesh its smooth as butter. So good to know that it’s good practise to collapse stacks when you no longer need to be able to “go back”.
Thanks!
Yes, thanks from me too! The modifier thing has been huge for me. On files where I have a linked FBX (from Revit or SketchUp) it’s motivation to bind the fbx sooner in the process so I can collapse stacks. Makes a huge difference, thanks again.
