Checkerboard/Sequential Tiles with Corona Tile Map
Hey Everyone,
I have been experimenting with the corona tile map couple with the multi-map recently.
Im struggling to figure out how to create a checkboard type finish with the maps being distributed sequentially. Does anyone have any advice?
do you have any reference for what you would like to achieve?
Hey! I’m repeating my question—I have a similar problem. I’d like to make every other tile black. Does anyone have an idea how to do it?
If it’s a simple “stack bond” pattern, then you could use the 3ds Max Checker map. I used Corona Tile with 5x5cm size and 0.1cm gap thickness. Then I used a Checker map with the tile dimensions x2 (10.2 x 10.2cm).
If it’s a different kind of pattern, then I don’t know if it’s possible at all…
@maru, what about custom tiles ID pattern? Do you think it would be possible to implement such feature? I think it would be really useful to many users.
I’m only qualified to say “that would be cool”, and redirect you to the ideas portal. :slight_smile:
Ok, it’s doable, as usual with no promises.
(Report ID=CMAX-1604)
That’s awesome to hear! Even if there are no guarantees :]
