hello, for our pipeline, it is essential to be able to output in exr and jpg the beauty or the other rendering passes. this is already possible in arnold and redshift but not in vray. you can choose only one format at a time. In vray its impossible.
it must be simple and automatic Thank you
Unfortunately we do not support writing different render elements to different file formats right now. I will make a note about this, but I’m not sure when we might be able to look into it. In the meantime you could probably run some script after rendering to convert the files as needed.
