Choosing Shader Type in Corona
material editor > Corona material > advanced options > BSDF
Only GGX and Ashikhmin-Shirley are supported for now.
Hello! I just installed A7 on 3DS Max 2012, and I can’t see this under advanced options. What could be the problem, and is there any way around it available to me?
GGX is currently in daily builds only.
I see. Would the Path Tracing Samples and Bounces be part of the dailies as well?
Thanks!
Hi guys!
I work with corona for some time, but only today I’ve noticed this parameter (see the attachment) which is visible only in slate mode of mat editor and only under Additional Params rollout. I’ll be very grateful if somebody can tell what each number of BRDF parameter means (0-3)? And why this parameter is hidden so deep ?))
What?
Path tracing samples: you mean GI/AA samples in main settings?
Bounces: ray depth in main settings?
Sorry for ggx, I keep forgetting that some features are in dailies only. :smiley:
To me GGX looks more “pearly” and “metallic”. A-S looks more plastic-like.
0 - Fong
1 - likes as Blinn
2 - default (Ashikhmin-Shirley. Some likes as Ward)
3 - Ward
Thank you for the answer!
Strange… I read alot about Corona Render, but I never see anything about this BRDF switcher…
Because you don’t need to pay attention to it, there was none. If it’s told the default (keep everything as it,don’t touch) works great, it does. Corona doesn’t have magic buttons being hidden anywhere.
Up to 7.2, it was hidden, and worked great. Default that is. (Ashikmin-Shirley BRDF)
From now on (Daily builds to final 1.0 version), you don’t need to touch it either, it works even better (GGX BRDF).
Thanks Maru! I’m only beginning to try out Corona, and plenty of the terms are still a little fuzzy to me. I look forward to trying GGX out soon as well. :smiley:
Thanks Juraj!
Corona is great and actually I never needed this switcher working with Corona, I didn’t have problem with material creation (except case with anisotropic reflection). I just was thinking - maybe I miss somthing useful? I read about GGX BRDF in Corona, I don’t have Daily builds, but I’m looking forward to try all new features announced by Corona team in Corona 1.0
uwelcome
I agree with Juraj and Maru - use default bcse it’s realy pretty good looks in compare with other brdfs
After release you will not want to use any brdf apart from GGX (;
Of the top of my head without being an expert i found this explanation of shaders.
http://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/3DSMax/files/GUID-D5D11F0A-0813-428B-B2F9-C60A54260726-htm.html
Basicaly a shader is code… simply as that. A code that interprets how a pixel is supposed to be seen.
Using this reasoning i would argue that a Coronamaterial is no better that a Standard one. BUT… a CoronaMtl is a shader writen by the maker of the engine that renders that shader so i’m assume that are highly optimized to work with Corona, and i could not say the same for a Standard shader even if Corona “supports” it.
Well… you made me open max and see if really i understand what is what in a Corona material. I think i pass the test Except for the last rollout (That nothing has to do with corona) the Mental Ray Connection. I really have no use for that last one. But for the rest i even know the limitations and bugs of some.
