Hi guys,
Just want to ask if there’s any possibility to add ‘’chromatic aberration’’ to the Corona VFB?
That will add a much more realistic look to all the images.
Thanks so much!
Jireh3D
Hi guys,
Thanks so much!
Jireh3D
Requested many times, so definitely will be considered.
Right now the only solution is to use some other application to apply it, or to fake it using DOF (unfortunately it is not a post effect, so no live control during/after render). Check out the very bottom of this guide: https://coronarenderer.freshdesk.com/support/solutions/articles/5000516203
In the meantime you can also use VFB+ which has been made availably for free. It also has some extras that can be quite handy. The only downside is that it won’t work with IR, works fine with final renders though. Note: it doesn’t have ‘proper’ CA where each channel is transformed from image center, instead it offsets each channel but the result is good enough.
http://www.monotoneminimal.com/vfb
AWESOME!! great to hear Maru!
I guess this could be nice. Maybe something along the lines of ArionFX’s HDR fringe?
Any news about this guys? Is it being considered? Something in-camera hdr fringe?
