Chromatic Aberration in Frame Buffer
Would be awesome to have Chromatic Aberration directly in the Frame Buffer.
thumb up on that idea. I also missed something like that once.
not everyday use, but to ctrl the vividness of it would be good from time to time, as I found on last task about some glas here I had to render
Hi, thanks for posting. This is on our to do list and it will eventually be added in a future release.
Thanks a lot Vladimir. This would be phenomenal. Any possible hints on this progress to get us excited? :slight_smile:
Most probably you’ll see it this year :slight_smile:
Awesome! Excited for it
Its not technically correct, but you can get a lot of nice photographic chromatic looks using coloured ramps as camera aperture maps. I controlled some colour fringing in high contrast areas in this shot using that technique.
Nice,
is this from a nightly?
This is available since many years, just add a custom map to simulate dispersion inside the physical camera DOF slot.
The chromatic aberration effect is now part of the VFB with the newest V-Ray 6 Update 2.
More about the release here.​
Thank you! And another thank you to the entire Chaos Group team for all of your hard work over the years. Been using this program for almost a decade and it has helped me build a sustainable career.
