Church Project
Hi everyone,
Church Project (C&C welcome).
looking good, but also looking a bit blue…
Nice palm trees, and it looks very naturally balanced.
I presume your using the VrayPhysical Camera with VraySky, so you can set the white balance on the camera to get rid of this blue-ness.
I think you basically change the white colour box in the camera parameters. You’d pick a colour in the rendering that is supposed to be white, and enter this. In your case, it would probably be something quite close to that path at the front i guess…
Beautiful sky as well by the way…
Leaving all parameters as they are, U could try to reduce the saturation parameter to 0.8 or even 0.6 and watch if reduce the blue at the level desired
bye :wink:
good start :smile:, your shadows are too blurred and too blue IMHO.
Thanks for the comments sv, pengo and priad. This was my first experiment using VrayPhysical camera and the Vray sun/sky system. I agree with your comments about the image being to blue in hue. I’m going to try out your suggestions and post and update.
Thanks Again! :slight_smile:
Trees and plants are ONYX.
A bit blue, and your shadows are a bit blurry, wich results in a strange shadow from the tree.
nice modeling thou..
Otherwise a very good result
Update:
A quick Auto Color change in Photochop. Have you tried changing the size of the sun to affect the shadow crispness?
Thanks sea2stars, 2 second auto color change looks good. I’m playing with the sun size now to see if I can get those tree shadows a little crisper.
:slight_smile:
a couple material suggestions, the grey concrete is flat. needs some sort of variation, and the roof tile is well too tiled (perfect) and soo flat( physicaly). Again some sort of variation would be very helpfull and some bump or displace to bring it up a bit
