CIE frame numbering change
i wonder if there is a way to set thte corona image editor batch, so it puts the frame-numbering at the end of the filename instead of the render-element name.
Most programms read sequences only with numbering at the end.
Regards, Stefan
We already have this logged as a feature request. Sorry, but no timeframe when to expect it yet.
(Internal ID=312723127)
The only workaround I can currently recommend is using an existing tool for renaming your files, or using a batch script for this, instead of doing it manually.
I am attaching a simple script which can rename files in the folder where it is placed from the following format:
to:
​So for example this file:
will be renamed to:
This will only work for files consisting of 3 keywords. If there are 2 or 4, it would have to be changed (for example in case of Post_Frane0001_CESSENTIAL_Direct.png).
If you decide to use it, I would definitely advise to experiment with a few files first, and make backups of the original files, just in case.
3-words-rename.bat (125 Bytes)
Thanks a lot.
I use “bulk rename utility”. Very comfortable tool.
