Cinema 2023 + Vray6 - freezing
Hello, copy/paste or opening a File - Cinema is freezing… Any idea? Without plugins - no problem! :frowning: LG Harry
Hello @HarrySeidl ,
Can you please share some more details about this issue? What are you trying to copy/paste? What are the exact versions of V-Ray and Cinema4D that you have installed? Also, what is your OS? Can you share a minidump file from the freeze? Please check this page for more information on how to generate it. Lastly, can you go to http://localhost:30304 and make sure that you are logged in with your account and that you have an active V-Ray for Cinema4D license? Thank you.
Hi @aleksandar.kasabov , I’ m working at the lates C4D-Version (2023.2.1) and Vray 6.00.05 and Windows10. If I copy an object in a szene and paste it in another scene, Cinema is freezing. Same problem with opening a project. I’m working with a lot of Cosmos-Objects. My License is ok. Thank you for helping!
Hello @HarrySeidl ,
Thank you for confirming those details. It would be very helpful for our team if you can send us a dump file from when the freeze occurs. Please follow the steps, described in the page from my previous post.
Also, let us know if you are using V-Ray (CPU) or V-Ray GPU. Thank you.
I have changed nothinger - standard-settings in Vray 6. Maybe the problem is, that the szene is older - Vray5 and C4D R26. When i open the szene in R26 - it works.
Don’t know if that’s the same issue but in the past I’ve had problem with older scene as well. In my case I’ve solved with this workaround, create a new scene, disable the material in the viewport by choosing the layer color option, merge the older scene in the new scene.
Thanks @sirio76 - I will try! :slight_smile:
Hey, Harry,
Thank you for the feedback. Could please try with Cinema2023 1.3, I personally experience the same issue when simple open new scene with 2023.2 and 2023.2.1, without V-Ray installed, but works well with 2023.1.3 release. Please let me know if you experience the same issue with 1.3.
Hello @HarrySeidl ,
Apart from the suggestions above, can you clarify whether your Cosmos assets are on a network location? If yes, what is the speed of your network? Thanks.
I have no troubles in C4D R26 with the latest Vray6-version! Only in 2023…
Hello @HarrySeidl ,
Could you please try the suggestions and provide the requested information from the previous post so we can assist you further with this issue? Thanks.
