I unchecked “Use Cinema 4D color space” in the Corona preferences because I want to use the Corona color space to get the exact same colors I see in the VFB. I noticed that the saved image sometimes shows slightly different colors compared to the VFB when using Cinema color space.
However, when I do this, I no longer get the usual save options. For example, when saving as JPG, it doesn’t ask me what quality I want to save at. Also, the saved image seems to use the monitor’s default color space (BENQ) instead of the one I’ve set on the monitor, such as sRGB.
I think we should still have access to the save options even when using the Corona color space, and there should be a way to choose which color space the image is saved in.
Does anyone know how I can keep the save options available with “Use Cinema 4D color space” unchecked, and how to save the image in sRGB (or ideally full RGB)?
Hi, sorry for the delay. I can confirm the JPG quality popup disappearing when “Use Cinema 4D color space” is disabled. I will try to find out whether this is expected and why.
This is actually expected at this point. When you disable the C4D color space, the file saving is handled by Corona, not C4D, and we don’t currently have format options options. This can be improved in the future, however having options for all possible image formats would be tricky.
It’s really unfortunate that this option isn’t available.
However, it would be very helpful if the PNG format could be saved as 16-bit by default, and if there were an option to enable or disable the alpha channel when saving.
I assumed that VFB and Corona Image Editor are built on the same core functionality.
When I open a saved CXR file in the Corona Image Editor, I can choose to export it as either 8-bit or 16-bit, as shown in the attached screenshot.
Would it be possible to implement this functionality in the VFB viewer as well?
I assume there has been no improvement regarding this issue. It is quite strange that after saving the render in CXR format, I can open it in the Corona Image Editor and export it to any format with all available options — 8-bit, 16-bit, with or without alpha channel, etc. — yet this is not possible directly in the VFB.
Here is one suggestion: if these export options cannot be implemented in the VFB in the near future, it might be helpful to add a button in the VFB that sends the entire render and all associated data directly to the Corona Image Editor, where we could handle the exporting ourselves.
The situation with color accuracy is particularly frustrating. My clients expect precise color representation for their products — fabrics, wood, and other materials. They often print the images and need the colors to be as close as possible to the real materials. When using Cinema color space and saving as a 16-bit PNG, the colors shift slightly compared to what I see in the VFB. Understandably, this can be a serious issue for some clients.
