Cinema 4D R20 and Corona
I hope Corona for C4D team aware of this plugin compatibility in R20.
Corona for C4D will be ready to use when R20 release or have to wait… ?
Interested to hear from Corona team.
Thanks.
Yes, we are well aware of R20 :wink:
Thanks… but it will work with R20 or have to wait for any update…!
Forget r20, let’s get v1.0 of Corona THEN we can talk.
Like each and every C++ plugin working with R19 will NOT work with R20, you will need a version compiled especially for R20 to run in R20.
well, beta2 is coming in 2 weeks…
eventually…
When can we expect the support of R20?
It’s already supported, grab it here:
https://drive.google.com/drive/folders/1Kfqwz77XXO6dhroC6HzwEXk9m9pSZuW9
I’ve updated c4d 20.028 and multi-instances doesn’t work anymore.
With standard c4d renderers, it’s ok but not with corona.
Are you talking about IR or a non-IR renderer?
With IR, it’s broken.
Ah, OK. This is a known issue. Multi-instances haven’t been implemented from our side with IR yet. It was never working correctly and we’re currently working on it.
With the previous version, it was ok.
This is interesting, because it shouldn’t have been. Can you please double-check this? Which version are you talking about?
c4d 20.026
Confirmed not working in R20.022 and R20.031S. It’s on wrike too :wink:
Some new info about Multi-Instance in C4D R20 and Corona Renderer 4?
corona-4-c4d-hotfix1 does not work CINEMA 4D Studio R20.059.
when will it work?
Works here.
I just downloaded the latest version of corona render 4rc1, there is no version c4d r20.059 in the installation menu. Tried to set the default, did not help.
