Cinema 4D + Redshift
Has anyone been able to test the latest version of Cinema 4D 2025 with the forced Redshift? Does Corona work well with this version?
By the way, very unfriendly of MAXON to force a function on their users, which not everyone uses but for which they charge extra. I already pay for a rendering plugin (Corona) that suits my needs much better than Redshift, and therefore I will not use it. Give us the choice, just like before, to pay for Redshift or not.
I can only see the Maxon app updated to 2025 but no C4D 2025 yet.
I did have problems opening C4D this morning and had to re-activate my licence. I did read something on ReEdit that you will no longer be able to rent/buy C4D only. I sincerely hope this is not true??? I will not be able to afford RS & Corona. If this is the case we need a REVOLT!!!
I find this pretty silly TBH. Every single DCC has a built in render engine. That Redshift was NOT the default seeme more unfriendly to me seeing that their leagacy Physical render was so far out of date.
Theres no reason that Corona will be effected beyond the fact that all new releases require a hotfix usually.
