Is there an ETA for S22 support?
Thanks,
Phil
Thanks,
Phil
What is cinema s22? ![]()
If you have a subscription then it is the latest version. Cinema 4D | 3D Animation & Modeling Software
Works for me out of the box. Only did a quick test though, so there might be some bugs or issues…
All the materials in the viewport appear black when I put a corona material on an object.
s22 shouldn’t break plugins AFAIK. So Corona shoud work OK. I wouldn’t rush to download yet though. There are bound to be some bugs in it
Yes, this is a known issue that has been reported.
For internal use only: (Internal ID=490874796)
I think I found the culprit…
“Still eager to work with but w/o obstruction?”
For scene assembly/modification disable Materials Option and Use Object Display Color properties.
To light and shade utilize IR/IRR.
BTW
Would be a great feature, if Object Display Color was “connected” to Material Diffuse Color ![]()
Any news related to black material on S22? Viewport is actually almost 50% smoother, but you can’t check the true performance through this error.
We found out the culprit and are testing the fix. It will most probably appear in the next daily, which should appear soon…
great thanks!
Those experiencing “black textures” in the viewport, this should now be fixed in the latest V6 daily. Please feel free to test it out and let us know if the probably remains.
good news, thx
I Need to install corona 5 on c4d S22, but it is invisible in c4d. Corona is installed because standlone works. What can i do?
Only Corona 6 (in daily builds) supports R22 (or S22 depending how you call it)
