I tested Vray 6 and the export to Vantage has not changed compared to the beta.
This export to a VR scene to Vantage is not usable, you can no longer show and hide objects. The transfer from Vray 5 was great because you could show and hide objects. I have also sent you example scenes.
Vray 5 Complete handover with stage rendering and objects that fade in and out is handed over with the timeline frames.
Vray 6 on and off are controlled with the timeline?
By when can I expect changes?
Or is something changed in Vantage so that objects can be shown and hidden there and it can be saved separately in each superordinate image?
Thanks very much!
I tested Vray 6 and the export to Vantage has not changed compared to the beta. This export to a VR scene to Vantage is not usable, you can no longer show and hide objects. The transfer from Vray 5 was great because you could show and hide objects. I have also sent you example scenes.
Yes, the hiding/unhiding issue is caused by the objects having equal names, as already mentioned here: Cinema 4D Vray 6 beta to Vantage - Vantage :: Issues - Chaos Forum . We haven’t changed anything and development for the issue hasn’t been started yet. If the issues is not name related and all objects have unique naming, then please send us another sample scene for us to examine(and also exported vrscenes from V-Ray 5 and V-Ray 6).
As for the stage object you have to ask on the V-Ray for Cinema forum for accurate roadmap and expected time frame.
