hi all,
this is my WIP from attached reference from houzz website
starting with walls and cabinets.
reference
](http://postimg.org/image/ap1bx7eqt/)
hi all,
reference
Looks like a good start,
In my opinion - stick to a single HDRI map or play which a sun position.
The reason is that I don’t think there are any direct sun light in you’r reference image which is important point if you want to stick to the lighting and mood.
Hi eli.
Thanks for comment, havent think about Light yet.
But Will keep in mind your tip.
o.k,
Just finished all main geometry, and start with lights.
HDRI + PORTAL from window, simple as that.
www.3dvision.co.il
hi all
some renders from scene , a lot of time is dedicated for create good modeling and materials.
for the first time my white color mat in material editor, looks white on render, and no grey or some weird color..
this is huge thing for me, that colors is output to scene as I meant in mat editor.
hi all.
another progress.
things i need to do:
I think you should seek to achieve whitepoint somewhere in the ceiling, where two different lights colliding (exterior and interior). So you should make it more blue than yellow, I suppose.
Besides that it’s very promising work!
thanks for comment, i think you are right.
the white burn fill from sunny day, is missing in my render.
My only gripe is about the floor. I’m not sure if its geometry or bump mapped, but the gaps just seem to wide/deep. otherwise very good work! Cheers
hi thanks,
You’re right about the floor. It has been taken care of.
hi again.
so, about the corona, test it, play with it, love it.
here is my final result.
comments are most welcome.
