Clay Render
it would be very helpful if the clay render button would appear again - is this possible in the next update? Even better, if this affects all materials, except glass.
Hi acidnoid,
I can’t remember if there was a “clay render” button in 3.6, nevertheless you can now just use the built-in material override in c4d’s render settings.
Yup! Glass and transparent object exclusion would be pretty nice :slight_smile:
Thank you for the hint - will try - in VRay 3.7 it was called material override
Riiight!
yup, the c4d override will do the same now + the exclusion list is super handy and “close”, so you can faster drag materials into it
