cleaning process in slow motion
In implicit mode, try to animate the velocity multiplier of Phoenix under the Rendering panel - this will work as a direct MB multiplier.
I could not reproduce the floating droplets though, are you using the default “Inscribed” voxel mode under the Interaction panel?
Thanks so much for the tip with the Velocity multiplier, that’s exactly what I was hoping for.
And yes I do use the “Inscribed” voxel mode.
It looks like a collision issue with the FLIP solver, you could either try to move a mesh up or down and hope for the best, or use a separate mesh for rendering, until the issue is resolved.
I think I will ignore it for now
Thanks for all your help so far. I will just keep asking if that is ok.
The waterjet I simulated is supposed to clean an object. I thought I could distribute some particles over the objects using particle flow, add the “Phoenix FD force” operator and be done.
Unfortunately I used inertial forces and animated the Phoenix Grid. The result is that the particles move with the grid. Like they are linked to it. Which would make sense if I had’t used inertial forces.
Is there some setting or workaround to counteract this effect?
Very strange, there was an issue with the particle force and inertial forces several months ago, and it was fixed. Is it possible to attach your scene or email it to the support team?
Sure here is the scene:
testscene_particle.zip (83.8 KB)
Yes, there definitely is a problem with the inertial forces, stay tuned for the fix or a workaround.
Ì will. Thanks a lot for your help.
Hi there, did you have time to take a closer look at this problem? Or should I think about a workaround?
the problem is resolved, but is still not uploaded to the builder , hopefully until the end of the week will be.
That’s great. Thanks a lot for this.
is the problem fixed in a current version?
yes, it should be
I am back to this project. I simulated the water again with a higher resolution. Now my render times are significantly higher. I am not sure if this is a vray or phoenix issue.
When I started the project the render times were fine. So I am kind of confused.
The scene renders in ~2 minutes (frame “108”) if I hide the water. If I unhide the water it takes ~45 minutes? The material is rather simple.
I uploaded the testscene if anybody wants to take a look
testscene.zip (4.43 MB)
i will see the scene, but it’s very probably this is expected behavior
Is there a way to increase render speed without loosing to much quality?
well, the first tip is to use mesh rendering mode, not implicit surface that is used in your scene.
but the most important is the particle rendering. you have one particle shader rendering the splash of the simulation. when the scene is relatively complex, the foam shader may lead to very big render times, because it is volumetric shader and slows down each ray passing near to the particles, even these that are not actually affected. the best solution is to render the splash in separate pass and add it in compositing,
I managed to get reasonable render times, thanks for your help.
I am back to particle flow and PhoenixForce now. I distributed particles over my object and added a deflector that follows the water jet. If the deflector hits the particles they are transmitted to a new particle flow event that contains a PhoenixForce operator with the water jet as Phoenix node. I was expecting that the particles therefore are driven by the water simulation. So they would stop if I would freeze the frame of the water jet by activating direct frame mode after some frames. Unfortunately they won’t. Was my assumption wrong? Do I have to freeze them in another way?
they are driven by the velocity simulation in the current frame, that means even if you have “frozen” by the input simulation, they still follow the velocity found in the currently loaded frame. the velocity is the same as when you play the animation with normal speed. well, this scenario was predicted, tha’s why the option “ignore time scale” was added, but unfortunately the play speed was introduced later, and this option gives in account only the simulation time scale, not the play speed. well, we will fix this
