Hello I was checking out the tutorial on linking wire parameters for the HDRI * Sun target rotation
I seem to be having alot of foreign crap in there - does anyone know of a script to clean these things out? Is it dangerous to just clean this?
Grts
It looks suspiciously similar to some 3ds Max virus. You may want to read this topic: https://forum.corona-renderer.com/ !Attention! - Virus in 3ds Max Stocks models!! Read article!!!
ok thanks ill run the script and see what gives. if its not a virus and just crap from other merged files and assets, is there a way to clean this up? is it dangerous to do so? would these wired things slow my scene down?
This looks more like the usual animation layers mess to me (global tracks which get accumulated after every merge). Prune scene script should handle it. You can also use this tiny one:
https://forum.corona-renderer.com/ HELP - file size problem #msg106638
Good Luck
Hi, can you send your scene for me?
I need to discover it. I guess it can be the viruses…
Try Prune Scene and let me know if it helped
