Clear Background
Hi guys,
How do you make a copy without background, the only way I found right now is to save with white background I must be doing something wrong
Thanks for your help everyone!
Hi @Midaz
What do you mean by copy? You can make a “layered” screenshot - this option will export depth and material additionally to the screenshot. You can then use material layer to cut out sky in post production. Check out “Capturing” tab in settings to enable it.
Thank you so much will try it ! you are the best!
