Clear Hisstory?
Hello, I hope you are well. Special thanks for producing a great Real-Time rendering engine and the support it has in the forum section.
How can I clear the history of parameters like the environment file section?
Currently this is not possible using the UI.
You can open the file named vantage.ini inside the %appdata%/Chaos Group/Vantage folder and edit it manually.
The environments are under .
Be careful when you edit the file, store a backup first or you might have to completely delete it.
Greetings,
Vladimir Nedev
