Clear VFB after rendering?
Is there a way to clear the VFB after rendering? I’m rendering an animation, and need to make a change to a material, so I’m using the selection mask feature. However the VFB keeps the previous render, and overlays the new frame. In this instance I rendered a mask pass, but is there a way to clear the VFB after each render?
Thanks,
Dean
There is such an option in Render Setup->System->Previous render (in advanced mode) - you need to set it to “Clear” and the VFB will be cleared after each frame.
Yavor
Brilliant, thank you!
