When using a Clipper Object in Mesh mode the Clipper Material Option doesn’t do anything. The Clipper is either taking the material from itself or from the clipped object. I guess this is expected behavior and works fine if understood, but shouldn’t the ‘Clipper Material’ option be greyed out, if i check ‘Mesh Mode’?
Hello @s_z ,
You are correct, in Mesh mode, V-Ray ignores the Clipper Material. It uses the clipper mesh’s own material, or the clipped object’s when “Use object material” is on. This is the expected behavior and we should grey out the Clipper Material when the Clipper is in Mesh mode. I have logged this in our internal system and we will let you know if we have any updates.
Thanks.
Hi Aleksandar, thanks for the confirmation.
