Closing the VFB takes forever - why ?
It happened in 2.4.x and now in 3.x - In the beginning everything is great but now everytime I close the VFB - it may take between 10-30 seconds !
Why ?
Is there a cache that can be deleted ?
Regards
NIR
Max Design 2014 Vray 3.00.07 Win7 64
Are you using the Nitrous viewport?
Yes
Shouldn’t it be working with it ?
Nir
I have also found that the VFB can get very slow after renders finish, when you go to clear the buffer and when you want to close the VFB. I hope you might be able to speed these processes up if possible. I’m also using Nitrous. 2014.
Try to disable “Improve Quality Progressively” under Display Performance of Viewport Properties.
Thanks - will try this.
Me too
Nir
OK
I tried it but it does not help - Actually it took a bit longer this time :frowning:
Nir
Ok; I’m working on some code that handles the VFB UI differently; it’s still experimental, but it might help for such cases and hopefully will go into one of the next updates.
Great stuff!
Nir
Sweeeeeeeeeeeeeeeeeeeet, Vlado is 1
Hehe, we’ll see. The way this experimental stuff is now, the 3ds Max UI remains active during rendering, which, while maybe useful occasionally, may also lead to unexpected problems, f.e. if you change a material during a render or go to File > Reset…
You mean that we can continue to work on the scene, tweak materials and other settings while rendering? This will be extremely beneficial!
Nonono. I mean that you can click on things that you shouldn’t :slight_smile: F.e. if you change a material, it will change how the rest of the render comes out (or crash, depending on exactly what you changed).
If you want to fire a render and continue working, simply use backburner, or make a script to fire a 3dsmaxcmd render.
Oh I see… had me all excited there for a minute. I’m allergic to backburner at the best of times.
If you did ever find a way to enable “background rendering” in a similar fashion to how Photoshop now works that would be tremendously useful.
