Hi!
I’ve seen some friends testing Corona las couple of months and decided to test it by myself today.
I’m really really impressed with quality and speed of Corona!
I’m working now on a short movie for my final graduation work and I’m testing Corona to completely replace V-Ray on this project, the results seems just perfect, nice lights and shaders and incredible fast renders!
But then I found this annoying bug, and after some test I found that the cloth simulation was causing it.
Well, after bake the cloth simulation keys It started to work perfectly, but until that, objects didn’t render in some frames, while in other frames the colors were messed up.
Since I will render just after finish all simulations, it’s not a big problem, I’ll keep testing and hope to render all my movi with Corona.
Thanks and congratulations!
By the way, the problem happens with animation only. When I render a single frame everything is ok.
If yours version is Alpha 6 can you post a part your scene (with this cloth sim) for testing on dayli build?
Hi! is it to be posted here or I should upload it somewhere else?
Yes, it’s Alpha V6 and I surely can provide it to help develop Corona.
I’m new on this forum, so I’m a bit lost, where exactly I’m suposed to post it?
Thanks!
I reccomend using some eternal server, like dropbox. Its always faster, and lighter for the Coronas serwers.
Your Napoleons face, looks quite “pinched” especialy lips. Overal looks quite nice, but that face.
Hi!
Thanks for the feedback.
I’ve uploaded the scene on mega, here is the link:
Please ignore de WIP character, it wasn’t an animation, just a test ![]()
I’ve tested the scene on 3 computers and always get the same bug.
I tested on DB and no problem with cloth:
You can see result here:
https://www.dropbox.com/sh/7mknzd2p8mclcz2/AADM7cg5jF7e7ix2K7iV-Vvia
Hi!
Well, it seems to be a problem with something here so…
I’ll check if I missed some 3ds Max SP or something like that, anything that could be different… I still get this error here at the office, and at home with my PC and Notebook (One of them with Windows 7 and two with Windows 8.1).
I tried to render your scene too and everything seems normal. But on loading, max gave warning about missing plugin “turbosmooth pro” or something similar. I wonder, maybe this plugin may be cause of problems?
no. I have this plug in my system and test passed
I think that this a6 bug.
I can’t make any test now because I’m at work, but I’ll try to reinstall 3ds max and run corona with no plugin installed, and then install the service packs of 3ds Max, maybe then I can realize where it’s happening.
If it happens on all my 3ds Max, it may be some plugin I have installed in all of them, or something like that.
I’ll post the results here.
Thanks for the help!
