Hi !
I’m getting the same issue described in this thread : Strange Reflection on Glass in the latest version. I thought this was fixed ? Is this a settings problem ?
JF
Hi !
JF
I am in trouble with this problem for such a long time too though. It generally turn normal by set all settings into default by pressing button “create new default setting”
You’ll generally get highly simplified reflections (only the sky will be visible) when you set the Rendering Quality in the Enscape Settings to Draft - setting it to anything from Medium to Ultra should very well help already.
In case it doesn’t kindly send me some screenshots of that behavior, preferably with the project itself if possible! ![]()
I never set quality to draft…
So this was resolved by just resetting your settings, or do you still experience any issues? ![]()
Indeed. Kindly make sure that your Rendering Quality in the General tab of our Enscape Settings is not set to Draft, but if you experience this on Medium - Ultra as well, then this is caused by the fact that we also revert to simplified reflections when looking through multiple layers of Glass. This is there to increase performance, otherwise the scene could get unstable pretty quickly if we were to render “true-to-life” reflections.
Still, as hardware gets better and better we’ll have the chance to also further increase the amount of reflections in complex scenes like these, so be assured that we’re always working hard to improve every aspect of Enscape.
